Finite Element coupling components: about
FE coupling components
The FE coupling components: coil conductor, solid conductor 2 terminals and solid conductor N terminals can be created:
- within the electric circuit editor context (graphically visualized component)
 - with the import of the electric circuit (graphically visualized component only according to the format)
 - directly in Flux (graphically non visualized component)
Graphic representation
In the circuit editor, the components are represented by the following graphic symbols:
| Stranded coil conductor | 2-terminal solid conductor | N-terminal solid conductor |
Orientation
The orientation of these components affects the finite elements method computation.
Electrical model
There is a model for the current-voltage characteristic proposed for each FE coupling component:
