Finite Element coupling components: definition (structure)
Definition
A stranded coil conductor, 2-terminal solid conductor or N-terminal solid conductor component is defined by:
- a name (and a comment)
 - a model
 - specific characteristics depending on the model
 - two terminals (stranded coil conductor/2-terminal solid conductor) / N terminals (N-terminal solid conductor)
Name
The name permitting the identification of the component is given by the user when it is created by him.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
FE coupling components: description
Characteristic quantities, necessary for the description of the FE coupling components: stranded coil conductor, 2-terminal solid conductor and N-terminal solid conductor, are presented in the table below.
| Stranded coil conductor component | Description |
| belonging to a circuit | Value of resistance in Ohm |
| with an imposed current | Value of the current in Ampere |
| Solid conductor component | Description |
| 2-terminal solid conductor | Information on symmetries and periodicities |
| N-terminal solid conductor | Information on symmetries and periodicities |
