Construction by propagation: about
Definition
The construction by propagation is a building method that allows the construction of new geometric entities based on already existing entities by using a geometric transformation like translation, rotation, …
In the figure below, the parallelogram (image) is built by propagation of the existing parallelogram face (source) using a translation vector.
Notice
We deal with:
- propagation, when the image object, generated by transformation, is not connected by lines to the source object
 - extrusion, when the image object, generated by transformation, is connected by lines to the source object
