Propagate points / Propagate lines
Before starting
It is necessary to have a transformation (created beforehand) and points / lines to be able to propagate points / lines.
Propagate points / lignes
To propagate points / lines:
| Step | Action |
| 1 |
                         Select the points / lines to propagate:
| 2 |
                         Activate the command *:
| → | A new dialogue box is opened. |
| 3 |
                         Fill out the fields:
| 4 |
                         Validate the information:
| → | The points / lines are created. |
| → | A new dialog box for the extrusion of entities of the same type is automatically opened. |
| 5 |
                         Quit the sequence:
