Options of construction by propagation
Building options
Some building options are proposed in order to simplify the user's work and to carry out semi-automatically a certain number of repetitive tasks.
These options, classified in three categories, are presented in the table below:
| The options … | allow … |
| for geometric building |
| for mesh preparation |
| for preparation of regions |
Options for geometric building
The options for geometric building allow to define the geometric entities (points, lines, faces, volumes) created during the propagation.
These options are presented in the table below:
| Action | Options available | |
| Add points, lines | Add points, lines faces | |
| Propagate Faces |
| Add points, lines | Add points, lines, faces, volumes | |
| Propagate Volumes | ||
Option for mesh preparation
Simultaneously with the faces and/or volumes construction, the option for mesh preparation allows:
- to create the linked mesh generator associated to the transformation used for propagation
 - to assign this linked mesh generator to the faces / volumes
This option is presented in the table below:
| Action | Available options | Name of mesh generator (automatically assigned) | |
| Creation of … | and assignment of … | ||
| Propagate Faces | linked mesh generator associated to transformation | mesh generator to created faces |
                         LINKED_NAMETRANSF  |
| Propagate Volumes | linked mesh generator associated to transformation | mesh generator to created volumes | |
Where NAMETRANSF is the name of the transformation.
For more information on linked mesh generator see chapter Mesh: software aspects.
Options for the preparation of regions: principles
The options for the preparation of regions allow:
- to create one or more surface / volume regions
 - to assign these regions to faces / volumes created by transformation, as well as to the base entities
| Creation of a region … | Example |
| for all faces / volumes created |
| for each face / volume created |
                         for a group of faces / volumes with the property of periodicity  |
Add a suffix
The user has the possibility to add a suffix to the name of the regions created by transformation in order to facilitate its identification. This suffix is added to the common generic name (REG_SURF for the surface regions and REG_VOL for the volume regions).
Options for the preparation of regions: details
The details of the options proposed for the creation and assignment of regions are presented in the table below:
| Option | Sub-option | Number of regions | Name of regions | |
| Propagation | Period | Suffix | ||
| with the same region | - | - | 1 | REG_i |
| with increment | - | SUF | n+1 |
                         REG _ I REG_SUF_i+1, … REG_SUF_i+n  |
| with periodicity | p | SUF | p |
                         REG _ I REG _ SUF_i+1 … REG _ SUF_p  |
where:
- n is the number of repetitive transformations (integer number)
 - i is the next number in the list of regions (integer number)
 - p is the periodicity (integer number)
 - REG is the abbreviation of REG_SURF (surface region) or REG_VOL (volume region)
 - SUF is the name of the suffix added to the name of the regions created by transformation
