Deletion of a component of the circuit in the circuit editor context
Introduction
In the circuit editor context, the components of an electric circuit can be deleted starting from two places: the Data tree or the Graphic sheet
Delete a component in the Data tree
To delete a component starting from the Data tree:
| Step | Action |
| 1 |
                         Select the component to be deleted:
| → | The component is highlighted |
| 2 |
                         Delete the selected component:
 or
| → | The component has been destroyed |
Delete one (more) component(s) in the graphic sheet
To delete one (some) components(s) in the Graphic sheet :
| Step | Action |
| 1 |
                         Select the component(s) to delete ( selection )
| → | The component(s) (which can be of different types) are shining |
| 2 |
                         Delete the selected component(s):
 or
 or
| → | The selection has been deleted |
