Running the algorithm in Flux PEEC
Launching the command
The execution of this algorithm is launched in Flux PEEC starting from the command "Create Geometric Tubes or Tube Points from assimilation volumes" which can be found in the menu "Tube Conductors".
In the following dialog box:
the user must first choose between the creation of Tube Points only and the creation of both Tube Points and Geometric Tubes approximating the volume taken into consideration.
The two options are described in detail in the Creation of Tube Points only and Creation of Tube Points and Geometric Tubes as well maps.
