Data export to OptiStruct
- Exports of time forces, generate a .fem file of force variation versus time at the nodes. Only real vector data collection, transient and multi-steps are compatible with these exports. The user should specify:
- The time interval to be exported. An error message appears if there is no data for one or several steps of a chosen interval for the data collection to be exported.
 - Exports of force harmonics, generate a .fem file of force variation
                        versus frequency at the nodes. Only the collections of the FFT derived type
                        are compatible. The user should specify:
- The harmonics to be exported (either all harmonics, an interval or a list of harmonics).
 - Exports of static forces, generate a .fem file of forces at the nodes
                        at current step. Only real vector data collections are compatible with these
                            exports.Note: In the framework of this export, with the option "Write vectors in compact mode" activated,the exported data are compacted in order to get faster computation in OptiStruct; consequently, when imported in OptiStruct, only the resulting force values will be displayed, not the components.
 - Static heat volume density exports generate a .fem file of static heat sources at the volume elements. Only real scalar data collections are compatible with these exports.
 - Time heat volume density exports, generate a .fem file of heat volume density variation versus time at the elements. Only real scalar data collections, transient and multi-steps, are compatible with these exports. The user should specify:
 - Exports of static temperatures, generate a .fem file of static temperatures at the nodes. Only real scalar data collections are compatible with these exports.
- A file name
 - The possibility of defining the support mesh in the exported file
 - The type of forces definition (forces at nodes or global force over a support)
The behavior of global forces export is explained here.
- The ID of the main LOAD card ( or DLOAD)
 - The ID of the coordinate system in HyperMesh (by default : XYZ)
 - The adding of BEGIN BULK and ENDDATA at the beginning and at the end of the file
