Exports to tabulated files
These exports enable the user to export the values of the data collection at the current step in a tabulated file. All the data collections are compatible.
- The type of value to be exported (to the nodes or to the elements)
 - The data collection to export
 - The name of the file to be exported
 - The column separator (option)
 - The column list of the file
Define the column list or a tabulated file
- A new column can be added by clicking on the blank page
 - The user can access the active column by clicking on the bin
 - The user can switch from one column to another using the arrows
 - Node or element ID
 - Node or element barycenter coordinates
 - Value at current step (complete value or specific component)
