How to create a set of Mechanical boundary conditions?
To create a set of Mechanical boundary conditions, click the Mechanical boundary conditions node of the Data tree:
Figure 1. The New Mechanical boundary conditions dialog box.
Then, in the New Mechanical boundary conditions dialog box:
- Provide a name for the Mechanical constraint;
 - Select an option from the Mechanical boundary conditions drop-down
                        menu representing the type of boundary condition. Two possibilities are
                            available:
- Constraint on degrees of freedom of nodes and
 - Constraint on node displacement.
 - In the case of a Constraint on degrees of freedom of nodes, the user
                        must inform if the nodal degrees of freedom
- Radial translation,
 - Angular translation and
 - Normal rotation
- On the other hand, for a Constraint on node displacement, the user
                        must provide explicit constraint values for:
- the Radial displacement (mm),
 - the Angular displacement (mm) and for
 - the Rotation (deg).
 - Finally, select the mesh nodes that will be subjected to the constraint. Two
                            Node selection modes are available:
- Node selection by line: applies the mechanical constraint to the mesh nodes lying on geometrical lines. A List of lines must be provided as an input.
 - Direct node selection: applies the mechanical constraint to the nodes identified by their numbering in the mesh.
