How to create a Mechanical problem?
To create a Mechanical problem, click the Mechanical problem node of the Data tree:
Figure 1. The New Mechanical problem dialog box.
Then, in the New Mechanical problem dialog box:
- Provide the Name of the problem;
 - Select the Mechanical problem type from the drop-down menu. Note: Only Mechanical problems of type Centrifugal load are available in Flux 2023.1. This kind of mechanical problem is well adapted for the description of a structural mechanics problem representing the rotation of a solid around an axis, as in the case of the rotor of an electrical machine. To fully describe a Mechanical problem of type Centrifugal load, provide the Rotation speed (rpm) of the rotating body represented by the Mechanical regions.
- Inform which of the previously created Mechanical regions integrate the problem by filling the List of mechanical regions.
- Similarly, inform which of the previously created Mechanical boundary conditions integrate the problem by filling the List of mechanical regions.
