Direct method for surface forces (dFmagS)
Introduction
This chapter discusses the use of the Direct method for surface forces (dFmagS) to create force collections in the Import / Export data context: this kind of collection allows to compute forces on a face mesh with the forces density dFmagS.
- Description of the approach
 - Creation of this force collection
 - Limitations
 - Example
Figure 1. Simple actuator with a yoke, a coil and a plate with a support described by a line and then extruded with the help of data supports.
Creation of this collection
- In the data tree, select the menu Forces data collection
 - In the dedicated GUI for Forces data collection, choose Direct method for surface forces (dFmagS)
 - Choose a data support to collect the data
 - Choose the collection interval:
- Collect for all the steps of the scenario
 - Collect only for the current step
 - Collect for a specified interval
 - Click OK
 - Right click on the forces data collection just created in the data tree and run the command Collect data
Limitations
- Only the forces normal to the support can be evaluated
 - This collection must be defined at the interface between two regions with different magnetic permeability
In this example, the aim is to compute the global force on the plate of the actuator shown in Figure 1.
To do this, we define a support to collect the data: it comes from the Flux mesh and is the same as the one described in Figure 1; it has been created from the line that we choose to extrude during the creation of the support.
Figure 2. Distribution of nodal forces in Newton on the actuator plate.
- The approach described on this page
 - With Computation on physical entity available in the tab Computation > On physical entity
| Approach | Force value (N) |
| Direct method for surface forces (dFmagS) | 4.53 N |
| Computation on physical entity (region) | 4.73 N |
