NFX-T: 1005 Simple Two Phase Gearbox
Set up a simple two phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution.
- Select Unit System
 - Import CAD Geometry
 - Define SPH Flow Solution
 - Define Air and Oil Properties
 - Define Initial Conditions
 - Define Body Force
 - Assign Motion
 - Create SPH Particles
 - Check Solver Settings and Result Request
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
