Adjust Ride Height
Use the Ride Height tool to adjust the heave, pitch, and roll of the model.
Adjust Heave
                From the Setup ribbon, Ride
                        Height tool group, click the Heave
                    tool.
- In the modeling window, select the dimension for the desired axle.
                In the microdialog, enter a value for height and press
                            Enter.
Adjust Roll and Pitch
                        Height tool group, click the Roll and
                        Pitch tool.
 Figure 3.
- Optional:
                Select fixed parts.
                - From the guide bar, select Fixed Parts.
- In the modeling window, select parts you would like to remain stationary.
 All wheel parts are stationary by default.
- From the guide bar, select Ride Height.
                In the modeling window, click the dimensions of the
                    desired wheels.
                Restriction: Only three dimensions can be active at a given time.The selected dimensions are activated.Tip: To deactivate a dimension, hold Ctrl and click the desired dimension.
                Edit the dimension height by completing one of the following:
                - In the microdialog, enter a value for height and
                        press Enter.
 Figure 4.
- In the microdialog, click  and use the graphical manipulators to adjust
                        the reference location. and use the graphical manipulators to adjust
 Figure 5.
 Tip: To reset a dimension value, click in the microdialog. in the microdialog.
                        press Enter.
                Position the vehicle by completing one of the following:
                - From the guide bar, select  to position the vehicle and continue adjusting
                        the pitch and roll. to position the vehicle and continue adjusting
                        the pitch and roll.
- From the guide bar, select  to position the vehicle and exit the
                        tool. to position the vehicle and exit the
                        tool.
