Create Coordinate Systems and Align Parts
Use the Systems tool to define local coordinate systems and translate the parts needed to align the model.
Import and Export Coordinate Systems
Associate Parts with Coordinate Systems
| Option | Description |
| With the Align Tool |
| With the List Systems Tool |
Scale Parts
When parts are transformed into a new coordinate system, the order of operations is to scale the part first, translate it to the origin of the new coordinate system, then rotate about the new origin.
- Hold Ctrl while left-clicking to select the scale field for multiple parts. Continue holding Ctrl while changing the scale value to scale multiple parts at once.
- Use the
and
icons
to search and filter parts.
