Create, Edit, Remove Parameters
Create, edit, and remove parameters using the HyperStudy Editor.
Before creating and editing parameters, the
                HyperStudy
            Editor requires a format to be set. For more information, see
                Parameter Format Specifiers.
    Create Parameters
                From the menu bar, click Tools > Editor.
                The Editor opens.
- In the File field, open the file to be used as the base input template.
                Highlight the appropriate fields in the text area.
                Tip: To assist in selecting a specified number of fields, press Ctrl to activate the Selector, enter the number of fields to select, then click a field in the text area. HyperStudy highlights the number of fields specified.
                Create a parameter.
                - Click Create.
- Right-click on the highlighted fields and select Create
                            Parameter from the context menu.
                In the Parameter - varname dialog, define the new
                    parameter.
- Click Apply to accept the input values.
- Click OK to finish creating the parameter.
Edit Parameters
                The Editor opens.
                Select the parameter to edit.
                - Highlight the parameter to edit in text area, then right-click and
                        select Edit from the context menu.
 Figure 3.
- In the row that contains the parameter to edit, click  and select Edit > varname from the context menu. and select Edit > varname from the context menu.
 Figure 4.
- In the Parameter - varname dialog, edit the parameter.
- Click Apply to accept the changes.
- Click OK to finish editing the parameter.
Remove Parameters
                The Editor opens.
                Remove parameter.
                - Highlight the parameter to remove in text area, then right-click and
                        select Remove from the context menu.
 Figure 5.
- In the row that contains the parameter to remove, click  and select Remove > varname from the context menu. and select Remove > varname from the context menu.
 Figure 6.
