Parallel Coordinate Post Processing
Visualize data trends.
Visualize Data Trends
Visualize all run data across multiple channels on a single plot in the Parallel Coordinate post processing tab.
A parallel coordinate plot is also known as a snake plot.
 (located above the Channel selector). For more information about these settings, refer
            to Parallel Coordinate Tab Settings.
            to Parallel Coordinate Tab Settings.Parallel Coordinate Tab Settings
Settings to configure the parallel coordinate plots displayed in the post processing step.
 (located above the Channel selector).- Absolute Scale
- Enable an absolute scale versus a relative scale, which is used by default.
- Show min/max
- Turn the display of min and max ranges on and off.
- Show Constraints
- Marks responses with constraint definition.
- Show Best Points
- Accentuate the best optimum run or runs. Dial tolerance value to add alternative optimum runs.
