Residuals Post Processing
Identify design errors.
Identify Design Errors
Identify design errors in the Residuals post processing tab.
View the Percent Error column with caution when the values of the output response approach zero. In this situation, the Percent Error can be very high and potentially misleading.
Figure 1. Cross-Validation Matrix Residuals
 (located
            in the top, right corner of the work area). For more information about these settings,
            refer to Residuals Tab Settings.
 (located
            refer to Residuals Tab Settings.Residuals Tab Settings
Settings to configure the results displayed in the Residuals post processing tab.
 (located above the Matrix Residuals
                    table).
                    table).- Input Matrix Residuals
- Display Input matrix residuals.
- Cross-Validation Matrix Residuals
- Display Cross-Validation matrix residuals.
- Testing Matrix Residuals
- Display Testing matrix residuals.
 , located next to the Channel selector.
