Set User Preferences File
A preferences file is an ASCII file that configures the application or its clients, and specifies default user settings such as the readers, functions, and solver script locations.
A standard preferences file is created in the program installation directory and is executed every time a license is activated. An additional preferences file can be created in your working directory, and can contain personal settings that will either overwrite the standard preferences file or be added to the existing settings in the standard preferences file.
- From the menu bar, select .
- In the Set Preferences File dialog, select your custom preferences file and click Open.
- Select a new custom preferences file by selecting from the menu bar.
- Disable the custom preferences file by selecting from the menu bar. The Use Preferences File checkbox should be off.
Preference File Reading Sequence
The locations and order in which HyperStudy will load preference files.
- Read main installation preference- getenv("ALTAIR_HOME") + "/hw/preferences_hst.mvw
- Read user preference files- getenv("USER_PREFERENCES_HST"(points directly to a file)
- getenv("USER_PREFERENCES_HST_DIR")/*.mvw(all *.mvw files in directory)
- Linux: (Linux) getenv("HOME")/.preferences.mvw
- Linux: <current working dir>/.preferences.mvw
- preferences.mvw(single file)- getenv("HW_SETTINGS_DIR")/HyperGraph/preferences.mvw
- Windows:
                                            C:/Users/<user>/Documents/HyperGraph/preferences.mvw
- Linux:
                                            $HOME/.altair/HyperGraph/preferences.mvw
- preferences/*.mvw(directory)- getenv("HW_SETTINGS_DIR")/HyperStudy/preferences/*.mvw
- Windows:
                                            C:/Users/<user>/Documents/HyperStudy/preferences/*.mvw
- Linux:
                                            $HOME/.altair/HyperStudy/preferences/*.mvw
- getenv(HW_CONFIG_PATH), a list of directories separated by semicolons- In every directory, HyperStudy tries to
                                        read <dir>/preferences.mvw
                                        read
- Read -preffile commandline argument
- Read registered GUI preference file
- Read study preference file (hstbatch only)- <studyDir>/_usr/hstudy_pref.mvw
