Create Reports
Package reports for data generated during the approach.
- In the study Setup, go to the Report step.
                Select the type of report to generate.
                Report Type Description HyperStudy Data Generates a data report (*.data). HyperStudy HTML Generates a HTML report and opens it in your default web browser. HyperWorks Session Generates a HyperWorks report (*.mvw) and opens it in HyperGraph. Knowledge Studio Text Generates data compatible with the Altair Knowledge Studio text import node. HyperStudy Fit Generates an input file for HyperStudy Fit model (*.pyfit). HyperStudy Spreadsheet Generates a spreadsheet report and opens it in Excel. In the Excel spreadsheet, click the Trade-Off sheet to perform trade-off studies in Excel, independent of HyperStudy. In a Fit Excel report, the Trade-Off 1D tab is a reflection of the corresponding Trade-Off 1D tab within HyperStudy. From the Trade-Off 1D tab in Excel, you can adjust the input variable values on the right-hand side to change the predicted output responses values displayed on the left-hand side.Restriction: To use this feature, you must add the HstAddinFit add-in to Excel. To install the Excel Plug-in for HyperStudy Fit engines, go to the <ALTAIR_HOME>\hst\plugins\externals\hstfitaddin\ directory and double-click hstfitaddin_install.vbs. The Excel Plug-in requires access to a valid license for all features to work properly.
- Click Create Report.
