HS-1605: Set Up ANSYS Workbench Model
Learn how to set up an ANSYS workbench model in HyperStudy.
There are no files associated with this tutorial.
HyperStudy’s interaction with Workbench is based on interpreting Workbench inputs as input variables and Workbench direct output as output responses. The inputs and direct outputs must be identified in the Workbench project file (*wbpj).
