plt3DIPlot PasteBarChart
Pastes the bar chart curve from the internal clipboard.
plt3DIPlot_handle PasteBarChart index
Tcl Query
- index
- The location to insert the bar chart curve in the number of curves in the current HyperGraph 3D window.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName AddBarChart
myPlotName GetBarChartHandle myBarChartName 1
myPlotName CopyBarChart 1
myPlotName PasteBarChart 1Errors
Success (0) or an error code.
