plt3DIPlot SetCurvePicking
Sets whether the client receives curve-picking information.
plt3DIPlot_handle SetCurvePicking enabled
Tcl Query
The default behavior when a waterfall is picked with the mouse is to report the varname of the waterfall. If you want to know which slice (curve) was picked, you must enable curve picking (a similar principle applies with curve groups).
- enabled
- Enabled, true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurvePickingErrors
None.
