plt3DIPlot SetPickApertureSize
Finds the size of the aperture.
plt3DIPlot_handle SetPickApertureSize pixels
Tcl Query
This command sets the size of the aperture. The aperture is box with lines coming out of it that is controlled by the mouse (instead of the arrow). The aperture allows you to pick things in the GUI.
- pixels
- The input for the pixels variable is a number representing the size that you want the aperture to be.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot SetPickApertureSize 20;Errors
Success (0) or an error is returned.
Keyword
- Tcl
- Note
- Plot 3D
- Query
