Sets the note offset distance from the entity center.
      bestview_handle
        SetNoteDistance
        distance
      HyperView Tcl Modify
      This command sets the note offset distance from the entity center. This distance is not
        followed during the global, globalregions, globalcomponents, or globalspheres view modes
        where multiple notes are present and there is a chance of overlap.
Note: To change the format
          and the contents of the best view note, you should create a note inside the current
HyperView window and label the note as “master” and then
          activate a best view. This can also be done using the poINote Class APIs under
            poIPost.
When a master note is present, the format and content of the master note will
            be followed for all best view evaluations.
          - distance
- The offset in screen percentage (0.1 would be 10% of the screen height and
            width).
      To set the note offset distance to
        20%:
bestview_handle SetNoteDistance 0.2
      Returns success (0) or an error code.
