SetNotePosition
Sets the position of the note for the best view around the entity.
bestview_handle SetNotePosition position
HyperView Tcl Modify
When a master note is present, the format and content of the master note will be followed for all best view evaluations.
- position
- The note position relative to the entity location. Valid options include:
              aboveleft,aboveright,belowleft,belowright, orauto.Note: The auto option follows the automatic placement of notes around the model as per the ArrangeNotes API described under poIPost.
bestview_handle SetNotePosition aboverightErrors
Returns success (0) or an error code.
