SetViewMode
Sets the view mode to be used for the best view.
bestview_handle SetViewMode mode
HyperView Tcl Modify
This command sets the view mode to be used for the best view.
- mode
- The view mode to be used. Valid options include: - global
- Shows all of the best views simultaneously and the entire model together in isometric view. SetHiddenSet can be used to hide a few components of your choice.
- globalcomponents
- Shows all of the best views and their parent components together, with everything else transparent in isometric view.
- globalregions
- Shows all of the best views and elements within a region size attached to the best view entities, with everything else transparent in isometric view.
- globalspheres
- Shows all of the best views and elements within a sphere around the best view entities, with everything else transparent in isometric view.
- globalallocation
- Shows only the best view on the current handle with the entire model visible in
                  isometric view, except the entities inside the hidden set. This is a single best
                  view version of the globalview mode.
- componenttransparency
- Shows only the best view on the current handle with only its parent component
                  visible in isometric view, everything else in the model in shown in transparency.
                  This is a single best view version of globalcomponentsview mode.
- isolatecomponent
- Shows only the best view on the current handle with only its parent component visible in a view normal to the current orientation of the element, everything else in the model is hidden.
- entityzoom
                  visible in a zoomed view normal to the current orientation of the element,
                  everything else in the model is hidden. This is a zoomed in version of
                    isolatecomponentview mode.
- contour
- Shows only one best view on the current handle with the entire model visible in
                  a view normal to the current orientation of the element. This is a localized
                  version of the globallocationview mode.
- transparency
- Shows only one best view on the current handle with the spherical region around
                  entity visible, in a view normal to the current orientation of the element. This
                  is a single view version of globalspheresview mode.
 Note: The default view mode isglobal.
hwi GetActiveClientHandle client
client AddBestView
client GetBestViewHandle bestview_handle1 1
bestview_handle1 SetEntity node 22460
client GetBestViewHandle bestview_handle2 [client AddBestView]
bestview_handle2 SetEntity node 22568
bestview_handle1   SetViewMode globalcomponents
bestview_handle1 ActivateView
client Draw true
Returns success (0) or an error code.
