poINote SetAttachment
Sets the note attachment method.
poINote_handle SetAttachment "attachment"
HyperView Tcl Modify
This command sets the note attachment method.
- "attachment"
- The attachment method. Options include:- window
- The note remains stationary when the animation image is repositioned in the window.
- "node model_id node_id"
- The note can be anchored to any node in the model. Note attached to model = model_id. Node with id = node_id.
- "element model_id element_pool element_id"
- The note can be anchored to any element in the model. Note attached to a model = model_id. Element pool = element_pool. Element with id = element_id. If the element pool is not specified, the selection will be done from the user pool as default.
- coord
- The note can be anchored to the XYZ coordinates of the model.
set model_id 1
set node_id 300
set elem_pool "my_elem_pool"
note_handle SetAttachment "node $model_id $node_id"
set element_id 20
note_handle SetAttachment "element $model_id $elem_pool $element_id"
set x 1.0
set y 1.0
set z 1.0
note_handle SetAttachment "coord $X $Y $Z"Errors
Returns 0 if successful, otherwise an error code.
