poINote SetPosition
Sets the note position.
poINote_handle SetPosition location
poINote_handle SetPosition {x_pos y_pos}
poINote_handle SetPosition {x_pos y_pos z_pos}
HyperView Tcl Modify
This command sets the note position.
This command has two possible argument types:- Two value list: used with the "screen" position type (see poINote::SetPositionType)
            - x_pos:
- The x coordinate on the screen; value between 0 (left) and 1 (right).
- y_pos:
- The y coordinate on the screen; value between 0 (top) and 1 (bottom).
- Three value list: used with the “coordinate” position type (see poINote::SetPositionType)
            - x_pos:
- The x coordinate in model coordinates.
- y_pos:
- The y coordinate in model coordinates.
- z_pos:
- The z coordinate in model coordinates.
poINote_handle SetPosition 0 0;
poiPost_handle Draw;
poINote_handle SetPosition 0.5 0.5;
poINote_handle SetPositionType coordinates
poINote_handle SetPosition 0.0 0.0 0.0
Returns 0 if successful, otherwise an error code.
