poINote SetTransparency
Sets the transparency attribute value (true/false).
poINote_handle SetTransparency value
HyperView Tcl Modify
This command sets the transparency attribute value (true/false).
- value
            - True
- Sets the transparency.
- False
- Does not set the transparency.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myPostName GetNoteHandle myNoteName [myPostName AddNote]
myNoteName SetTransparency trueErrors
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
