poIPost AddSection
Adds a new section of the specified type to the current client.
poIPost_handle AddSection type_args
HyperView Tcl Modify
This command adds a new section of the specified type to the current client.
- type_args
- Specify the section type between planar and spherical.0: planar 1: spherical Note: Section handle commands for planar and spherical sections are under poISection and poISphericalSection respectively.
hwi OpenStack
hwi GetActiveClientHandle post_handle
# create a planar section
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# create a spherical section
post_handle GetSectionHandle section_handle [post_handle AddSection 1]
hwi CloseStack
Returns the newly created section ID if successful, otherwise a null value is returned if AddSection failed.
