poIPost GetQueryRuleList
Gets the list of query rules from the client.
client_handle GetQueryRuleList
HyperView Tcl Query
This command is used to get the list of query rules from the client.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID1 [client AddQueryRule mindist]
client GetQueryRuleHandle distance_rule_handle $ruleID1
distance_rule_handle SetDistance "20"
set ruleID2 [client AddQueryRule extreme]
client GetQueryRuleHandle extreme_rule_handle $ruleID2
extreme_rule_handle SetExtreme "TopN 2"
client GetQueryRuleList
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the post handle does not exist anymore.
