poIPost RemoveQueryRule
Removes query rule from the advanced query.
client_handle RemoveQueryRule id
HyperView Tcl Modify
This command removes query rule from the advanced query.
- id
- Accepts a rule ID.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
client RemoveQueryRule $ruleID
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the post handle does not exist anymore.
