Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
The vehicle library models most four-wheeled vehicles in production today. Models can be modified interactively in MotionView to support topologies that are not supported in the vehicle library. The vehicle library is open-source, ASCII-based, and can be modified by you. The methods in the vehicle library can also be used and adapted to model non-automotive land vehicles, such as tractors and trucks.
A widely used process in the automotive industry is to split the suspension design and development into three distinct
stages. The stages are typically performed by different teams working in different locations and at different times during
the vehicle program. Ideally, the teams will share model data, modeling methods, and results widely. Since the teams are
working on the same vehicle, the engineering lessons learned by one group will need to be shared with the other two
teams.
The rear suspension model is built using the same process as the front suspension. Eleven different rear suspensions are
available using the Assembly Wizard.
A Braking in a Turn event simulates a vehicle decelerating in a circular path. The purpose of this event is to measure the stability of a vehicle
while braking and turning. The vehicle is driven straight for the entry length and then turns onto the circular path.
At the time to apply brakes, the brake torque is ramped on using the brake step duration time so the vehicle slows at
the desired deceleration rate. The event ends at the end of simulation time.
The Constant Radius event simulates a vehicle driving in a circular path. The Constant Radius event maintains a constant turn radius and varies the vehicle velocity to produce increasing amounts of lateral acceleration.
Steering and torque controllers maintain the path and the speed of the vehicle through the event. A plot template is available
to plot the results. The Constant Radius event is used to characterize the roll and understeer characteristics of a vehicle.
A Double Lane Change event drives the vehicle through a lane change and a return to lane maneuver, attempting to follow the centerline of the defined
lane. You can define the speed of the lane change, along with the lane dimensions. A steer controller is used to follow
the path and a drive torque controller is used to maintain speed throughout the event. The event supports right and left
lane changes. A plot template is available to plot the results.
A J-turn event simulates a vehicle response to a large steer in one direction, a dwell time to allow the vehicle to react, and a large
steer in the opposite direction, with an additional reaction time. The event is used to characterize the stability of
vehicles. Both steer directions can be run by reversing the sign of the steering inputs. A drive torque controller is
used to maintain a constant speed and standard outputs for the vehicle and tires are included in the tire system and the
output requests system. A plot template is available to plot the results.
The Kinematics and Compliance (K&C) test is performed by applying a range of forces at the two contact patches of a half-vehicle
model to determine the suspension’s characteristics. The motion of the wheel caused by the force application is measured
and recorded during this event. This in turn helps to determine suspension hard point locations, spring rates, bushing
rates, arm lengths, and so on.
A Power-off in a Straight Line event simulates the dynamics of a vehicle due to a sudden removal of drive torque. A steer controller drives the vehicle on
a straight line and the drive torque controller maintains speed until the throttle is removed. Engine motoring torque
is not applied after the throttle torque is removed. A plot template is available to plot the results.
A Pulse steer event simulates a vehicle response to a sudden pulse input to the steering wheel while driving in a
straight line at a constant speed. The input to the event can be a steering wheel torque or angle, and you can set
the pulse magnitude and width. The pulse can be input as a sine, step, or ramp function and you control the width.
A drive torque controller is used to maintain a constant speed, and standard outputs for the vehicle and tires
are included in the tire System and the output requests system. A plot template is available to plot the results.
The Single Lane Change event drives the vehicle through a single lane change, attempting to follow the centerline of the defined lane. You can
define the speed of the lane change, along with the lane dimensions. A steering controller is used to follow the
path and a torque controller is used to maintain speed through the event. The event supports right and left lane changes.
A Sinusoidal steering event simulates a vehicle driving at a constant speed while a sin wave input is applied to the
steering wheel. The event is used to simulate the On-center steering test described in SAE paper 840069. Standard
vehicle outputs are included in the event. Body state variable output requests (displacement, velocity, acceleration)
are included in the body system and tire output is included in the tire system. A plot template is available
The Static Ride analysis is a simulation of both wheels moving up and down, in phase, with the steering wheel held
fixed. The chassis is fixed-to-ground. The displacement of the wheel center is prescribed by the user. The suspension
moves via a simple control system and a “suspension test rig”. The wheel is constrained at the tire patch location
to the suspension test rig using an in-plane joint. Standard suspension requests (caster, camber, toe, etc.)
are included as part of the ride analysis and are described here. The front and rear suspension ride analyses are
similar.
A Step Steer event simulates vehicle response to a sudden step input to the steering wheel. The steering input is a rotational motion
or torque at the steering wheel or the input shaft to the steering gear. The standard output requests are
included to measure vehicle response. Tire requests are included to understand tire forces during the event. A drive
torque controller is added to maintain constant speed during the event to drive the vehicle forward. A plot template
A Straight Line Acceleration event simulates a vehicle accelerating at a constant rate in a straight line. The event is designed to characterize the
chassis behavior during acceleration. A drive torque controller applies a controlled torque to the vehicle
drivetrain to maintain the requested acceleration. Output requests are included to measure the vehicle behavior, tire
response and other common vehicle system metrics. A plot template is available to plot the results.
A Straight Line Braking event simulates a vehicle slowing in a straight line. The steering wheel is normally held fixed but can be released. A
braking torque controller applies torque at the wheels to slow the vehicle and appropriate output requests
are included. A plot template is available to the plot the results.
A Swept Sine event simulates a vehicle driving at a constant speed with a sinusoidal steering input of constant magnitude but increasing
frequency applied. Output Requests are included to measure the vehicle state variables, tire forces, and tire
state variables. A Drive torque controller is used maintain the constant velocity of the vehicle. A plot template
A Swept Steer event simulates a ramped steer input into a vehicle driving at a steady speed. The event is typically used to predict the
steady state dynamic response of the vehicle. Input can be steering wheel angle or torque. Standard vehicle
output requests are included in the event. A drive torque controller is included to maintain constant speed. A plot
A Throttle-off Cornering event simulates the dynamics of a vehicle driving a constant radius turn at steady state and the reaction of the vehicle
due to a sudden removal of the drive torque while cornering. The event includes a short straight section to
allow the vehicle to come to steady state, the constant radius circle, throttle removal, and the subsequent vehicle
reaction. A left or right turn can be simulated. The appropriate vehicle and tire output requests are included. A
A Throttle-off Turn-in event simulates the dynamics of a vehicle driving a constant radius turn at steady state, the reaction of the vehicle due
to a sudden removal of drive torque during the cornering event, and the reaction of the vehicle to a slowly
applied ramp steer. The event includes a short straight section to allow the vehicle to come to steady state, the
constant radius circle, throttle removal, and the increasing ramp steer. The event is designed to simulate a highway
exit ramp maneuver with a decreasing radius turn on the exit ramp. Appropriate vehicle and tire output requests are
included. A plot template is available to plot the results.
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard, located on the Assembly ribbon. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
The attachments specified during the assembly process (using the Assembly Wizard dialog) can be modified using the
Attachment Wizard, located on the Assembly ribbon. The Attachment Wizard dialog guides you through the process of modifying the model attachments.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
velocity to produce increasing amounts of lateral acceleration. Steering and torque controllers
Understeer
Two desired vehicle behaviors underlie the concept of understeer: as the vehicle
speed on a constant radius path increases the driver must increase the steer angle to
follow the path, and when the speed increases to the point where the vehicle reaches
its limit of lateral acceleration the vehicle drifts outward to a larger radius (yaw
rate stops increasing) rather than spinning (increasing yaw rate). The latter behavior
requires that the front tires lose adhesion before the rear tires. In front wheel
drive vehicles one can induce excessive understeer by applying throttle so the front
tires lose adhesion.
Neutral-Steer
For a neutral steer vehicle the steer angle required to follow a constant radius is
constant independent of speed. However, the vehicle side-slip angle must increase with
increasing speed to develop the necessary lateral force, requiring the driver’s
careful manipulation of the steering and/or throttle to balance the vehicle and avoid
a spin.
Oversteer
For an over-steer vehicle the steer angle required to follow a constant radius
decreases with speed making the vehicle very difficult for a driver to control.
Alternatively, a step steer input to an oversteering vehicle will cause the vehicle
lateral acceleration and yaw rate to increase to the point where the vehicle spins. In
contrast, a step-steer input to an understeering vehicle generates a limited lateral
acceleration and yaw rate.
Vehicles with poorly designed suspensions and/or poorly
chosen tires may show understeer but transition to oversteer for some combinations
of speed, lateral acceleration and vehicle loading.
Computing Understeer
Understeer is the difference between the average front and rear tire slip angles.
For a neutral steer vehicle the slip angles will be the same, for an understeering
vehicle the front slip angles are of greater magnitude than the rear slip angles,
while for an oversteering vehicle the rear slip angles are of greater magnitude than
the front slip angles.
Here:
= Slip-angle: The angle in radians measured from the
velocity vector to the tire heading looking downward from above the tire. Figure 1.
The event can be run in lateral acceleration control mode or in velocity control mode. In
lateral acceleration control mode, the vehicle is driven at a constant speed around the
circular track, which results in a constant lateral acceleration.
In velocity control mode, the vehicle is driven at an increasing speed around the circular
path, which results in an increase in lateral acceleration. Using the event form, you can
control the driving time, constant radius, and end speed.
Figure 2. Constant Radius Event
Figure 3. Top View of a Constant Radius Path
Figure 4. Vehicle Model with Body Graphics
The event is designed to drive a vehicle on a constant radius at either a constant lateral
acceleration or at a steadily increasing speed. The event begins with a straight section of
road that allows the vehicle to come to steady state. The vehicle enters the turn and the
controllers maintain the desired velocity or lateral acceleration.
Lateral Acceleration Control
If lateral acceleration is selected for the vehicle control, the event is run at a steady
state lateral acceleration. A target lateral acceleration and the radius of the track are
entered in the form. The vehicle initial speed is calculated using the equation
v=sqrt(r*a). The equation is embedded in the form.
The event sequence is described in the table below:
Event Step
Start
Vehicle begins driving in a straight line towards the constant radius circle tangent
at the speed that will generate a Lateral Acceleration that was entered in the
form.
Turn into Constant Radius Track
Vehicle enters the constant radius track. Turn direction is determined from the form
entry (left or right). Steering is controlled by the steer controller. Speed is
maintained by the drive torque controller. Lateral acceleration should be constant
(because speed is constant).
Follow the Constant Radius
The vehicle follows the constant radius path for the time defined in the event.
End of Event
The event ends when the time in circular track time is met.
A series of lateral acceleration control events is typically run to characterize the
vehicle. A series would include left and right turns (to understand the symmetry of the
vehicle) and a sweep of lateral accelerations to characterize the behavior of the vehicle as
acceleration increases. The track radius should match the radius of the test track being
used to generate correlation data.
Velocity Control
When the vehicle control is velocity, the vehicle drives around the track at a steadily
increasing speed and as a result, an increasing lateral acceleration. This event provides a
sweep of the lateral acceleration behavior of the vehicle (at increasing speeds). Left and
right turn directions can be run and the time in the circle can be varied to provide a
slower acceleration. The vehicle makes multiple loops around the circle if there is enough
time. The event sequence is shown in the table below.
Event Step
Start
The vehicle drives toward the tangent of the Constant radius path. The initial speed
is determined from the Circle Radius and the desired initial Lateral Acceleration. Low
accelerations result in lower initial speeds.
Turn into Constant Radius Path
The vehicle turns into the Constant radius path and begins to accelerate.
Follow Constant Radius Path
The vehicle drives along the Constant radius path and increases speed. The vehicle
speed is increased from the initial speed to the final speed in the Time in circular
track time. Use a longer time to minimize acceleration effects on the results.
Event End
The event ends after the Time in circular track time is complete.
If the model cannot maintain the circular path, the error Could not Find
Ideal SWA in 20 Iterations is sent to the log file. This is a generic error
that indicates the path is not being followed. It can be caused by a wide variety of issues
with the model and the tires. Examine the model results at the time prior to the error being
displayed to understand what the vehicle may be doing.
Nine types of modeling element containers are used to define the event. Three sub-systems
(output requests, a steer controller, and a drive torque controller) are also included in
the event.
Datasets
One dataset is used in the system and it contains the data used to describe the Constant Radius event. The event allows you to set the vehicle control, lateral
acceleration, final vehicle velocity, time in the circular track, circle radius and turn
direction (left or right). The vehicle velocity, wheel rotational velocities and ground
height are calculated values and should not be changed.
Forms
The form is the only place that you should change the lane change event. circle radius,
turn direction, time in the circular track, vehicle control, lateral acceleration and final
vehicle velocity are the parameters that can be changed. The ground z coordinate and initial
vehicle velocity are calculated values. The ground z coordinate is calculated using the
wheel CG Z location and the tire rolling radius from the tire data.
Graphics
One graphic is defined in the event. The graphics define the road surface graphics and
should not require any user input. A full description of the graphics can be found here.
Skidpad graphics are included to illustrate the path being driven, and are defined
parametrically using the data in the Constant Radius event form. Skidpad
graphics should never require editing unless the event is being fundamentally changed.
Figure 5. Skidpad Graphics
Joints
A ball joint is included in the Constant Radius event. The joint attaches a
dummy body to the steering rack. The joint is included to make certain events work in ADAMS.
Attach the dummy body to the steering rack if building a model manually.
Markers
One marker is included in the Constant Radius event. The path origin is the
origin of skidpad graphics and is parametrically defined to be the CG of the vehicle body.
The markers refer to points, and the points contain the parametric logic.
Motions
Three motions are included in the event. The steering motion to the vehicle is provided by
the steer controller and acts on a revolute joint that connects the steering column to the
vehicle body. If a steering column is not included in the model, the joint acts between the
steering rack input shaft and the vehicle body.
The front and rear wheel motions act on the wheel spindle revolute joints that connect the
wheel hub to the knuckle. The motion is initially zero (fixing the wheels to the knuckle) so
the model converges statically. The motions are deactivated after the static equilibrium
analysis to allow the tires to rotate.
Points
Two points are defined in the event. All points are used to create the skidpad graphics.
The points contain parametric logic to define their X, Y, and Z locations. You should not
need to modify any points.
Solver Variables
The Constant Radius event consists of only one solver variable, the Steer Path
Variable, which calls a user subroutine to apply an input at the steering wheel in order to
follow a desired path.
The numbers in the solver variable USER subroutine call are as follows:
Number
Branching ID. 5020 is a Constant radius event.
70000000
The ID of a solver array containing Driver Model Controller data. The array is in
the steer controller system.
70000100
The ID of a Vehicle Data array containing vehicle information. The array is in the
30
The value of the circle radius.
Templates
A template is included in the Constant Radius event task. The template is
solver specific, and only the MotionSolve template is
documented. The template is inserted in the solver deck after the </Model>
command and controls the execution of the event.
