Road Course Drive
The Road Course Drive event can be used to simulate full vehicle models on the required road profile. Different path and velocity profiles can be specified to validate the vehicle behavior on the specified road. The event also provides a means to study vehicle performance in the areas of durability/fatigue and ride comfort.
The Road Course Drive event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries.
| Parameter Name | Description |
| Path profile | Defines the path used by the Altair Driver in the event. Three options are
                    available:
| Velocity profile | Defines the velocity profile used by the Altair Driver in the event. Two
                  options are available:
| End time [s] | End time for the simulation. |
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS- Use additional control: Enables the additional feedback control for the traction
                  control. The gains for the controller can be edited by toggling this check
                    box.
Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
                    box.
- Leaning events (Two-wheelers)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS - Use additional control: Enables the additional feedback control for the traction
                    box.
                    box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Road
- Uses a flat smooth road for the event with no required road file.When the Flat Road is selected, the Graphics Setting option is available with the following parameters:- View path centerline: Enables the visualization of the event path.- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
 Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Troubleshooting Tips
- The road property file should be compatible with the tire property file that is used in the vehicle.
- The units in the path profile will be used when the independent variable in the velocity profile is set to Distance.
- The MotionView curve entity used to define the velocity profile should have the same units as specified in the Units field.
- The road centerline option will work (to generate the ddf), only if the road property file provided can be used by the Roads tools functionality.
