Result Configurator
The Report Configurator tool allows you to quickly create a Word document or pictures.
Entity Selection
Select available Components (Parts) and/or Element Set; with the sub-option Isolate Selected/Contour on Complete Model, the selected entities will contoured and isolated on the screen or contoured only on the whole model respectively.
Select Load Cases
Result Configurator
- Set Up on Active Window
Figure 3.
- Select from Session
- Figure 7.Figure 8.
- Export to New Word (for Windows system only)
- Export Using Existing Word (for Windows system only)
- Export Pictures (for Windows and Linux)
Export to New Word
This option will generate a new chapter for each selected results. Each chapter will have a sub-chapter for each selected load case which then will have again a dedicated sub-chapter for each selected parts.
This approach is similar to the previous one, however you will be asked, after the selection, to point to an existing document or template. The organization of the chapters is the same as the previous use case, however the headings will be taken from the document set up.
Export Pictures
After selection of the configuration, you will use these functions to input a destination directory in which the tool will create a subfolder for result, then a sub folder for each load case, and then a picture for each selected part/set.
