Advanced Options Dialog
The Advanced Options dialog allows you to customize a number of parameters which control how the streamlines are generated.
Figure 1. Advanced Options Dialog
| Integration method | ||
| Runge-Kutta2 | Second order Runge-Kutta integration scheme. | |
| Integration step length | ||
| Element-fraction | Fraction of local element size to be used as the step length for integration. | |
| Decimation criteria (used to reduce the memory consumption) | ||
| Decimation | Enable streamline decimation. | |
| Max break angle | Maximum break angle (in degrees) between consecutive streamline segments. | |
| Max speed variation | Maximum variation of speed (in percentage of the average vector field over the domain) between consecutive streamline segments. | |
| Max line segment length | Maximum streamline segment length in percentage of bounding box size. | |
| Termination criteria | ||
| Max length | Maximum length of a single streamline. | |
| Max number of steps | Maximum number of integration steps for a single streamline. | |
| Terminate speed | Terminates the streamline integration if the speed is smaller than the percentage of the average vector (velocity) field over the domain. | |
