Keyboard Shortcuts & Mouse Controls
Selection
| To do this | Press |
| Select multiple rakes | Press Shift or Ctrl + Left Mouse Click |
| Select all rakes | Press the Ctrl + A |
View new features for Altair HyperWorks 2023.1.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
Create your own user defined coordinate systems or select result coordinate systems.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
HyperView offers CFD post-processing capabilities for a large class of industrial applications.
Use the Streamlines tool to generate streamlines using any available nodal or elemental vector field (typically a velocity field).
Use the Tracking tool to track any entity during animation.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
