Create a Folding Table
Use the Create Table tool to create a table on which the airbag will be folded.
This is a shell part that will be rigid. The dimensions are computed from the size of the airbag, and the elements are regularly and equally spread. The meshing line can then be used as an indicator of the positions.
You should start with an airbag model with properties, materials and contacts.
