Ale Reference System Switch
Ale Reference System Switch entities allows for the time-dependent switches between different types of reference systems, that is, switching to multiple PRTYPEs at different times during the simulation.
This command is required only when PRTYPE = 6 in ARSG card.
LS-DYNA Cards
| Card | Description |
| *ALE_REFERENCE_SYSTEM_SWITCH | Allows for the time-dependent switches between different types of reference systems. |
