Supported Cards
Supported cards organized by solver.
Abaqus
ADVC
2D Element
3D Element
3D Gasket Element
Isotropic
Orthotropic
Anisotropic
Gasket
ElasticPlastic/Elastic Attributes
von Mises with Isotropic Hardening
ElasticPlastic / von Mises with Isotropic Hardening
ElasticPlastic / von Mises with Kinematic Hardening
ElasticPlastic / von Mises with Combined Hardening
Control Cards
ANSYS
The input translator recognizes the ANSYS cards listed below. If an unsupported field is found in a card, a message is displayed on the status bar. The messages are also printed to the file ansys.msg. General slash commands, SOLUTION commands, POST1 commands, and POST26 commands are referred to as control cards. Unrecognized cards are written to a *.hmx file. Nodes and elements support up to nine digits. ET block is supported.
Note: One component collector is created for every unique combination of Type, Real, Mat, and SECNUM. Surface loads on 1D elements is not supported. Property collectors are created for each real set defined in the ANSYS deck. Material collectors are also created for each material ID encountered. The component in HyperMesh is different from the component (CM) in ANSYS.
EXODUS
Feko
LS-DYNA
Nastran
OptiStruct
PAM-CRASH 2G
Permas
Radioss
Radioss Starter
Radioss Engine
