Load Step Inputs
Load step inputs organize and manage the IDs of analysis parameter bulk cards.
Nastran Cards
| Card | Description |
| ACSRCE | Defines the power versus frequency curve for a simple acoustic source. |
| DLOAD | Selects a dynamic load to be applied in a transient and
                frequency response analysis subcase. The DLOAD command can also
                be used to select a user-defined loading curve to be applied in a nonlinear static
                analysis subcase.  Note: Subcase Information Entry
Enable the subcase definition DLOAD and select load collectors with dynamic loading information (DLOAD, RLOAD1, RLOAD2, TLOAD1, TLOAD2).  |
| EIGC | Defines data needed to perform complex eigenvalue analysis |
| EIGRA | Defines the data required to perform real eigenvalue
                analysis with the Automated Multi-Level Sub-structuring technique. Note: Bulk Data Entry
| EIGRL | Defines data required to perform real eigenvalue analysis
                (vibration or buckling) with the Lanczos Method. Note: Bulk Data Entry
| NLPARM | Activates nonlinear solution methods for this subcase
                and to select the parameters used for Nonlinear Quasi-static Analysis, Geometric
                Nonlinear Implicit Analysis, and Nonlinear Direct Transient Analysis. Note: Subcase Information Entry
| RGYRO | Includes data required to perform Rotor Dynamics analysis
                in Modal Frequency Response Analysis and/or Modal Complex Eigenvalue Analysis. The
                  RGYRO Bulk Data Entry is referenced by a corresponding
                  RGYRO Subcase Information Entry in a specific
              subcase. Note: Bulk Data Entry
| RLOAD1 | Defines a frequency-dependent dynamic load of the form: for use in frequency response problems |
| RLOAD2 | Defines a frequency-dependent dynamic excitation of the form: for use in frequency response problems |
| TLOAD1 | Defines a time-dependent dynamic load or enforced motion of
                                    the form: |
| TLOAD2 | Defines a time-dependent dynamic excitation or enforced
                                    motion of the form: |
OptiStruct Cards
| ACSRCE | Defines acoustic source as a function of power vs.
                frequency. Note: Bulk Data Entry
| BASELIN | Baseline correction |
| DLOAD | Defines a dynamic loading condition for frequency response
                problems as a linear combination of load sets defined via RLOAD1
                and RLOAD2 entries, or for transient problems as a linear
                combination of load sets defined via TLOAD1 and
                  TLOAD2 entries, or acoustic source ACSRCE
                entries. Note: Bulk Data Entry
| EIGC | Defines data required to perform complex eigenvalue
                analysis. Note: Bulk Data Entry
| EIGRA | Defines the data required to perform real eigenvalue analysis
| NLADAPT | The NLADAPT entry can be used in the Subcase
                Information section to select the parameters used for Large Displacement Nonlinear
                Quasi-static Analysis, Small Displacement Nonlinear Quasi-Static Analysis, and
                Nonlinear Transient Analysis. Note: Subcase Information
                                    Entry
| NLENRG | Energy variable output |
| NLMON | This NLMON Subcase Information Entry can be used to
                activate Nonlinear Monitoring for a subcase by referencing a corresponding NLMON
                Bulk Data Entry. Note: Subcase Information
                                    Entry
| NLOUT | The NLOUT entry can be used in the Subcase Information
                section to select the incremental result output parameters used for Nonlinear Static
                Analysis and Nonlinear Transient Analysis. Note: Subcase Information
                                    Entry
| NLPRINT | Controls printing message. |
                   for use in frequency response problems.
                  RLOAD2 (Form 2) can be used when the frequency-dependent
                dynamic load input is available in magnitude/phase number format. Note: Bulk Data Entry
| RLOAD2 | Specifies directional combination method, modal combination
                method, excitation direction(s), response spectra and scale factors. Note: Bulk Data Entry
| TLOAD1 | Defines a time-dependent dynamic load or enforced motion.
                motion. Note: Bulk Data Entry
| UNBALNC | Defines the unbalanced rotating load during a rotor
                dynamic analysis in Frequency Response solution sequences. The unbalanced load is
                specified in a cylindrical system where the rotor rotation axis is the
              Z-axis. Note: Bulk Data Entry
