Create Acoustic Elements
Use the Acoustics tool to create 0D/1D acoustic elements.
An acoustic element is an element created in a space between two nodes/single node of a model where acoustic properties are desired. Acoustic can translate to available types depending on selected solver interface.
Update Acoustic Elements
Use the Entity Editor to update acoustic elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
