Create Electric Elements
Use the Electrics tool to create 1D electric elements.
Electric elements are general circuit-elements applicable to circuit simulation.
Electric elements have up to size nodes to define the circuit component and one or two degrees of freedom per node to model the circuit response.
Update Electric Elements
Use the Entity Editor to update electric elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
