Fuse Closed Shells
Use the Fuse: Closed Shells tool to create watertight volumes for CFD and thermal applications with closed shells.
View new features for Altair HyperWorks 2023.1.
Define meshing preferences.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Explore the different types of 2D mesh you can create in HyperMesh.
Supported 2D elements.
Explore the tools used to create 2D mesh.
Explore the tools used to create surface mesh.
Explore the tools used to edit 2D mesh.
Use the Auto Quality tool to automatically correct element quality.
Use the Edit Elements tools to manually improve the quality of surface mesh elements and nodes.
Use the Normals tool to reverse the normals of shell elements or surfaces. The orientation of unassociated shell elements or FE geometry can also be adjusted. The normal of an element is determined by following the order of nodes of the element using the right-hand rule.
Use the Orientation Review tool to display/review and modify frequently used coordinate systems used in CAE analysis.
Locally refine 2D elements and attached 1D elements using either the Auto Quads tool, the Box tool, or the Manual tool. These are most useful for aerospace and marine applications, where specific transition patterns are required from the refined mesh to the existing mesh.
Use the Imprint tool to imprint geometry or mesh onto target surface/lines or elements creating new edges/fixed points or a mesh patch respectively.
Use the Fuse tool to connect close proximity, overlapping, and intersecting parts.
Use the Fuse: Open Shells tool to automatically connect open shells to resolve penetrations/intersections, or prepare a BIW model for an electromagnetic analysis.
The Fuse tool can be used with several types of analyses where mesh connections are required.
Use the Hole/Gap Fill tool to fill holes, gaps, and patches in first order and second order elements.
Use the Cut Hole tool to generate holes in surfaces/2D mesh/FE geometry using various kind of shapes.
Use the Surface Repair tools to find, review, and fix any geometric errors in the model's surfaces.
Use the Split tool to split plates or solid elements. In addition, hexa elements can also be split using a technique that moves progressively through a row of elements in the model
Explore the different types of 3D mesh you can create in HyperMesh.
to define fuse
options.
