HyperWorks
HyperWorks
2023.1
  1. Home
  2. PhysicsAI
  3. Load PhysicsAI Ribbon
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
    • Load PhysicsAI Ribbon
    • Create and Load Projects
      Each session starts with creating a new project or loading an existing project.
    • Create and Manage Datasets
      Datasets are collections of one or more simulation results used for training or scoring a model.
    • Train Models
      Train models using any physics, any mesh, and without design variable parametrization.
    • Test Models
      Use the Model Testing tools to test models and review test results.
    • Predict Results
      Use the predict tool to generate a model prediction.
    • Confidence Score
      Like all machine learning models, PhysicsAI models are most accurate when the design being predicted is similar to the designs used for training.
    • Frequently Asked Questions
      This section provides quick responses to typical and frequently asked questions regarding physicsAI.
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. ...
    • PhysicsAI
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
ON THIS PAGE
    1. Open HyperMesh.
    2. From the menu bar, click View > Ribbons > PhysicsAI to open the PhysicsAI ribbon.
    ON THIS PAGE
