Predict Results
Use the predict tool to generate a model prediction.
View new features for Altair HyperWorks 2023.1.
Each session starts with creating a new project or loading an existing project.
Datasets are collections of one or more simulation results used for training or scoring a model.
Train models using any physics, any mesh, and without design variable parametrization.
Use the Model Testing tools to test models and review test results.
Like all machine learning models, PhysicsAI models are most accurate when the design being predicted is similar to the designs used for training.
This section provides quick responses to typical and frequently asked questions regarding physicsAI.
