Cross Sectional Properties Calculated by HyperBeam
The beam cross section is always defined in a y,z plane.
The x-axis is defined along the beam axis. The coordinate system you define is called the local coordinate system; the system parallel to the local coordinate system with the origin in the centroid is called the centroidal coordinate system; the system referring to the principal bending axes is called the principal coordinate system.
For shell sections, only the theory of thin walled bars is used. This means that for the calculation of the moments and product of inertia, terms of higher order of the shell thickness t are neglected. Thickness warping is also neglected.
Area
A=dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiabg2da9maapeaabaGaamizaiaadgeaaSqabeqaniabgUIiYdaaaa@3B6C@
Area Moments of Inertia
Iyy=z2dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG5bGaamyEaaqabaGccqGH9aqpdaWdbaqaaiaadQhadaahaaWcbeqaaiaaikdaaaGccaWGKbGaamyqaaWcbeqab0Gaey4kIipaaaa@3F98@
Izz=y2dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG6bGaamOEaaqabaGccqGH9aqpdaWdbaqaaiaadMhadaahaaWcbeqaaiaaikdaaaGccaWGKbGaamyqaaWcbeqab0Gaey4kIipaaaa@3F99@
Area Products of Inertia
Iyz=yzdA MathType@MTEF@5@5@+=feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG5bGaamOEaaqabaGccqGH9aqpdaWdbaqaaiaadMhacaWG6bGaamizaiaadgeaaSqabeqaniabgUIiYdaaaa@3FA1@
Radius of Gyration
Rg=IminA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBaaaleaacaWGNbaabeaakiabg2da9maakaaabaWaaSaaaeaacaWGjbWaaSbaaSqaaiGac2gacaGGPbGaaiOBaaqabaaakeaacaWGbbaaaaWcbeaaaaa@3DBC@
Elastic Section Modulus
Ey=Iyyzmax MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBaaaleaacaWG5baabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG5bGaamyEaaqabaaakeaacaWG6bWaaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaaaa@4009@
Ez=Izzymax MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBaaaleaacaWG6baabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG6bGaamOEaaqabaaakeaacaWG5bWaaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaaaa@400B@
Max Coordinate Extension
ymax=max|y| MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyEamaaBaaaleaaciGGTbGaaiyyaiaacIhaaeqaaOGaeyypa0JaciyBaiaacggacaGG4bWaaqWaaeaacaWG5baacaGLhWUaayjcSdaaaa@41F8@
zmax=max|z| MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOEamaaBaaaleaaciGGTbGaaiyyaiaacIhaaeqaaOGaeyypa0JaciyBaiaacggacaGG4bWaaqWaaeaacaWG6baacaGLhWUaayjcSdaaaa@41FA@
Plastic Section Modulus
Py|z|dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBaaaleaacaWG5baabeaakmaapeaabaWaaqWaaeaacaWG6baacaGLhWUaayjcSdGaamizaiaadgeaaSqabeqaniabgUIiYdaaaa@3FCA@
Pz|y|dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBaaaleaacaWG6baabeaakmaapeaabaWaaqWaaeaacaWG5baacaGLhWUaayjcSdGaamizaiaadgeaaSqabeqaniabgUIiYdaaaa@3FCA@
Torsional Constant
Solid
It=Iyy+Izz+(zωyyωz)dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG0baabeaakiabg2da9iaadMeadaWgaaWcbaGaamyEaiaadMhaaeqaaOGaey4kaSIaamysamaaBaaaleaacaWG6bGaamOEaaqabaGccqGHRaWkdaWdbaqaamaabmaabaGaamOEamaalaaabaGaeyOaIyRaeqyYdChabaGaeyOaIyRaamyEaaaacqGHsislcaWG5bWaaSaaaeaacqGHciITcqaHjpWDaeaacqGHciITcaWG6baaaaGaayjkaiaawMcaaaWcbeqab0Gaey4kIipakiaadsgacaWGbbaaaa@5435@
ω - Warping function
(see below for warping function)
Shell open
It=13t3ds MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG0baabeaakiabg2da9maalaaabaGaaGymaaqaaiaaiodaaaWaa8qaaeaacaWG0bWaaWbaaSqabeaacaaIZaaaaOGaamizaiaadohaaSqabeqaniabgUIiYdaaaa@404A@
t - Shell thickness
Shell closed
It=2AmiFsi MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacaWG0baabeaakiabg2da9iaaikdadaaeabqaaiaadgeadaWgaaWcbaGaamyBaiaadMgaaeqaaOGaamOramaaBaaaleaacaWGZbGaamyAaaqabaaabeqab0GaeyyeIuoaaaa@4177@
Ami MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaBaaaleaacaWGTbGaamyAaaqabaaaaa@38C8@ - Area enclosed by cell i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@
Fsi MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBaaaleaacaWGZbGaamyAaaqabaaaaa@38D3@ - Shear flow in cell i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@
Elastic Torsion Modulus
Solid
Et=Itmax(y2+z2+zωyyωz) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBaaaleaacaWG0baabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG0baabeaaaOqaaiGac2gacaGGHbGaaiiEaaaadaqadaqaaiaadMhadaahaaWcbeqaaiaaikdaaaGccqGHRaWkcaWG6bWaaWbaaSqabeaacaaIYaaaaOGaey4kaSIaamOEamaalaaabaGaeyOaIyRaeqyYdChabaGaeyOaIyRaamyEaaaacqGHsislcaWG5bWaaSaaaeaacqGHciITcqaHjpWDaeaacqGHciITcaWG6baaaaGaayjkaiaawMcaaaaa@533F@
Shell open
Et=Itmaxt MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBaaaleaacaWG0baabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG0baabeaaaOqaaiGac2gacaGGHbGaaiiEaiaaysW7caWG0baaaaaa@405C@
Shell closed
Et=Itmax(Fsit) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBaaaleaacaWG0baabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG0baabeaaaOqaaiGac2gacaGGHbGaaiiEamaabmaabaWaaSaaaeaacaWGgbWaaSbaaSqaaiaadohacaWGPbaabeaaaOqaaiaadshaaaaacaGLOaGaayzkaaaaaaaa@434F@
Shear Center
ys=IyzIyωIzzIzωIyyIzzIyz2Iyω=yωdA,Izω=zωdA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=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@717B@
zs=IyzIyωIyzIzωIyyIzzIyz2 MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOEamaaBaaaleaacaWGZbaabeaakiabg2da9maalaaabaGaamysamaaBaaaleaacaWG5bGaamOEaaqabaGccaWGjbWaaSbaaSqaaiaadMhacqaHjpWDaeqaaOGaeyOeI0IaamysamaaBaaaleaacaWG5bGaamOEaaqabaGccaWGjbWaaSbaaSqaaiaadQhacqaHjpWDaeqaaaGcbaGaamysamaaBaaaleaacaWG5bGaamyEaaqabaGccaWGjbWaaSbaaSqaaiaadQhacaWG6baabeaakiabgkHiTiaadMeadaqhaaWcbaGaamyEaiaadQhaaeaacaaIYaaaaaaakiaaysW7aaa@5401@
Warping Constant (normalized to the shear center)
Iωω=ω2dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaBaaaleaacqaHjpWDcqaHjpWDaeqaaOGaeyypa0Zaa8qaaeaacqaHjpWDdaahaaWcbeqaaiaaikdaaaGccaWGKbGaamyqaaWcbeqab0Gaey4kIipaaaa@4204@
Shear deformation coefficients
αzz=1Qy2(τxy2|Qz=0+τxz2|Qz=0)dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=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@5957@
αzy=1QyQz(τxy|Qy=0τxy|Qz=0+τxz|Qy=0τxy|Qz=0)dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=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@6F81@
αzz=1Qz2(τxy2|Qy=0+τxz2|Qy=0)dA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=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@5956@
Shear stiffness factors
kyy=1αzz MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4AamaaBaaaleaacaWG5bGaamyEaaqabaGccqGH9aqpdaWcaaqaaiaaigdaaeaacqaHXoqydaWgaaWcbaGaamOEaiaadQhaaeqaaaaaaaa@3EB2@
kyz=1αyz MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4AamaaBaaaleaacaWG5bGaamOEaaqabaGccqGH9aqpdaWcaaqaaiabgkHiTiaaigdaaeaacqaHXoqydaWgaaWcbaGaamyEaiaadQhaaeqaaaaaaaa@3F9F@
kzz=1αyy MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4AamaaBaaaleaacaWG6bGaamOEaaqabaGccqGH9aqpdaWcaaqaaiaaigdaaeaacqaHXoqydaWgaaWcbaGaamyEaiaadMhaaeqaaaaaaaa@3EB2@
Shear stiffness
Sii=kiiGA MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBaaaleaacaWGPbGaamyAaaqabaGccqGH9aqpcaWGRbWaaSbaaSqaaiaadMgacaWGPbaabeaakiaadEeacaWGbbaaaa@3E7A@
Warping Function
2ω=0 MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaey4bIe9aaWbaaSqabeaacaaIYaaaaOGaeqyYdCNaeyypa0JaaGimaaaa@3BFC@
(ωyz)ny+(ωz+y)nz=0 MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaeWaaeaadaWcaaqaaiabgkGi2kabeM8a3bqaaiabgkGi2kaadMhaaaGaeyOeI0IaamOEaaGaayjkaiaawMcaaiaad6gadaWgaaWcbaGaamyEaaqabaGccqGHRaWkdaqadaqaamaalaaabaGaeyOaIyRaeqyYdChabaGaeyOaIyRaamOEaaaacqGHRaWkcaWG5baacaGLOaGaayzkaaGaamOBamaaBaaaleaacaWG6baabeaakiabg2da9iaaicdaaaa@4F14@
For solid sections, the warping function is computed using a finite element formulation. This may lead to un-physically high stresses in geometric singularities (sharp corners) that get worse with mesh refinement. This may cause problems computing the elastic torsion modulus.
Nastran Type Notation
/1=Izz MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaai4laiaaigdacqGH9aqpcaWGjbWaaSbaaSqaaiaadQhacaWG6baabeaaaaa@3B62@
/2=Iyy MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaai4laiaaikdacqGH9aqpcaWGjbWaaSbaaSqaaiaadMhacaWG5baabeaaaaa@3B61@
/12=Iyz MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaai4laiaaigdacaaIYaGaeyypa0JaamysamaaBaaaleaacaWG5bGaamOEaaqabaaaaa@3C1D@
K1=Kyy MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiaaigdacqGH9aqpcaWGlbWaaSbaaSqaaiaadMhacaWG5baabeaaaaa@3B7F@
K2=Kzz MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiaaikdacqGH9aqpcaWGlbWaaSbaaSqaaiaadQhacaWG6baabeaaaaa@3B82@
