Loading [MathJax]/jax/output/CommonHTML/jax.js
*MAT_077_O (OGDEN_RUBBER)
LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified using the Ogden material models.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_077_O or *MAT_OGDEN_RUBBER
mat_ID ρi ν N_pair
If N_pair = 0, insert these two lines.
μ1 μ2 μ3 μ4 μ5
α1 α2 α3 α4 α5
If N_pair > 0, insert this line.
SGL SW ST Fct_ID DATA
In all cases, add up to 12 lines.
Gi β i
Definition
mat_ID Material identifier.
(Integer)
ρi Initial density.
(Real)
[kgm3]
v Poisson’s ratio.
Default = 0.495 (Real)
N_pair The number of material parameter (μi and αi) pairs calculated in the representation of the strain energy density function (W). The material parameters are calculated from the given stress-strain curve (fct_ID).
(N_pair ≤ 5)
Default = 2 (Integer)
μ1 - μ5 Parameter of the shear hyperelastic modulus.
(Real)
[Pa]
α1 - α5 Exponent of the shear hyperelastic modulus.
(Real)
SGL Specimen gauge length. [m]
SW Specimen width length. [m]
ST Specimen thickness. [m]
Fct_ID Function identifier for the force versus change in gauge length. Compression is defined in the 3rd quadrant (negative) and Tensile is defined in the 1st quadrant (positive).
(Integer)
[Nm]
DATA Experimental data type.
= 1 (Default)
Uniaxial test data.
(Integer)
Gi Shear modulus for relaxation. [Pa]
β i Decay constant for relaxation. [1s]
  1. This keyword maps to /MAT/LAW42 (OGDEN) (if N_pair = 0) or /MAT/LAW69 (N_pair > 0).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
