*MAT_169 (ARUP_ADHESIVE)
LS-DYNA Input Interface KeywordDefines adhesive bonding material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_169 or *MAT_ARUP_ADHESIVE
mat_ID ρi E v TENMAX GCTEN SHRMAX GCSHR
PWRT PWRS
Definition
mat_ID Material identifier.
(Integer)
ρi Initial density.
(Real)
[kgm3]
E Young’s modulus.
(Real)
[Pa]
v Poisson's coefficient.
(Real)
TENMAX Yield stress in tension.
(Real)
[Pa]
GCTEN Energy per unit area for bond to fail in tension.
(Real)
[Jm2]
SHRMAX Yield stress in shear.
(Real)
[Pa]
GCSHR Energy per unit area for bond to fail in shear.
(Real)
[Jm2]
PWRT Exponent value for failure in tension.
(Real)
PWRS Exponent value for failure in shear.
(Real)
  1. This keyword maps to /MAT/LAW83, /FAIL/SNCONNECT, and /PROP/TYPE43 (CONNECT).
  2. The material is fully compressible in the vertical direction from solid element face 1 to face 2.
  3. The tension stiffness is in the vertical direction and shear stiffness is perpendicular to the vertical direction.
  4. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
